Ik ben verplan om een nieuw luidspreker set te kopen voor mijn drive-in show, mijn oog viel op Hk audio.
- 2 keer Hk Audio Pro 18 passieve subwoofer.
- 2 keer Hk Audio Pro 15 passieve Luidspreker.
[FONT=Arial]Title[/FONT]
[FONT=Arial]PREMIUM Page Ranking:O - PR:O 18 S[/FONT]
[FONT=Arial]Product class[/FONT]
[FONT=Arial]Passive Systems[/FONT]
[FONT=Arial]Model[/FONT]
[FONT=Arial]PR:O 18 S[/FONT]
[FONT=Arial]Info[/FONT]
[FONT=Arial]High-power-capacity 18" subwoofer with high-quality crossover for powerful low-end kick.[/FONT]
[FONT=Arial]Power-handling nominal (RMS)[/FONT]
[FONT=Arial]500 W[/FONT]
[FONT=Arial]Power-handling, program[/FONT]
[FONT=Arial]1000 W[/FONT]
[FONT=Arial]Frequency response +/- 3dB[/FONT]
[FONT=Arial]48 Hz – 150 Hz (internal wedge)[/FONT]
[FONT=Arial]Frequency response -10 dB[/FONT]
[FONT=Arial]38 Hz – 150 Hz (internal wedge)[/FONT]
[FONT=Arial]Axial sensitivity 1W[/FONT]
[FONT=Arial]104 dB[/FONT]
[FONT=Arial]Maximum SPL @1m[/FONT]
[FONT=Arial]129 dB[/FONT]
[FONT=Arial]Nominal impedance[/FONT]
[FONT=Arial]4 Ohm[/FONT]
[FONT=Arial]Connections[/FONT]
[FONT=Arial]2x Speakon[/FONT]
[FONT=Arial]Speaker[/FONT]
[FONT=Arial]1 x 18"[/FONT]
[FONT=Arial]Crossover frequency[/FONT]
[FONT=Arial]150 Hz/12 db Octave[/FONT]
[FONT=Arial]Dimensions (WxHxD)[/FONT]
[FONT=Arial]53 cm[/FONT][FONT=Arial] x 61 cm x 64 cm, 20 3/4“ x 24“ x 25 1/4“[/FONT]
[FONT=Arial]Weight[/FONT]
[FONT=Arial]41.6 kg/ 91.52 [/FONT]
[FONT=Arial]PR:O 15[/FONT]
[FONT=Arial]The PR:O 15 is a classic full-range cabinet for all applications[/FONT]
[FONT=Arial]Power rating[/FONT]
[FONT=Arial]RMS: 400 W[/FONT]
[FONT=Arial]400W[/FONT]
[FONT=Arial]800 W[/FONT]
[FONT=Arial]60 Hz – 19 kHz[/FONT]
[FONT=Arial]53 Hz – 19 kHz[/FONT]
[FONT=Arial]128 dB[/FONT]
[FONT=Arial]8 Ohm[/FONT]
[FONT=Arial]Subwoofer[/FONT]
[FONT=Arial]1x 15“[/FONT]
[FONT=Arial]Tweeter/ driver[/FONT]
[FONT=Arial]1“[/FONT]
[FONT=Arial]2 kHz/12 db Octave[/FONT]
[FONT=Arial]Pole mount[/FONT]
[FONT=Arial]DuoTilt™ speaker-stand mounting collar for fast, easy installation[/FONT]
[FONT=Arial]Rigging points[/FONT]
[FONT=Arial]3x M8[/FONT]
[FONT=Arial]47 cm[/FONT][FONT=Arial] x 61,5 cm x 41 cm, 18 1/2“ x 24 1/4“ x 16 1/4“[/FONT]
[FONT=Arial]21.1 kg[/FONT][FONT=Arial], 46[/FONT]
Wat vinden jullie van het merk en van de luidsprekers?
Alvast bedankt,
Luuk
Alvast bedankt,
Luuk
