Ik koop waarschijnlijk
Deze set :
Soundpack 12 Aktivsystem inkl. Schutzhüllen - Active Systems
This set consists of: [LIST][*]1x 12" subsoofer[*]2x 6,5"/1" tops[*]2 professional Speakon cables[*]2 high-quality speaker stands[*]three piece protective cover set[/LIST]
features subwoofer:
1x 120 Watts RMS [LIST][*]Max. SPL: 118 dB[*]Frequency response: 40 - 150 Hz[*]Connectors: 2x Speakon Out, 2x XLR Out, 2x Combination Input (XLR / 1/4" Jack)[*]15 mm multiplex[*]Surface: PU coating[*]Speaker stand mount: aluminium[*]Front grille: steel with black active rubber foam[*]With handles for easy transport[*]Incl. wheels[*]Dimensions (WxHxD): 420 x 480 x 500 mm[*]Weight: 28 kg[/LIST]
features top: [LIST][*]6,5" + 1" satellite[*]120 Watts RMS[*]200 Watts Peak[*]Impedance: 4 Ohms[*]Max. SPL: 114 dB[*]Frequency response: 150 - 19000 Hz[*]Crossover frequency: 3500 Hz[*]Dispersion: 90° x 60°[*]Connectors: Speakon[*]Material: 15 mm Multiplex[*]Speaker stand: aluminium[*]Front grille: steel with black active rubber foam[*]Surface: PU coating[*]With handles for easy transport[*]Dimensions: 250 x 370 x 230 mm[*]Weight: 8 kg[/LIST]Wat vinden jullie ervan
Het is voor max 60 personen
En ik ben nog een beginner...
Mvg,
Emile
Deze set :
features subwoofer:
Mvg,
Emile
