Martin Mac550 (opvolger van de Mac 500)
  • LJ Gerrit
    • 479
    Bijgaand de specificaties van de nieuwe Martin Mac550. De wereldprimeur vindt plaats over twee weken op de Plasa 2003.
    Het is een heel verhaal maar ik wilde niemand iets onthouden.
    Lamp:
    The MAC 550 uses a brand new version of existing lamp technology from Osram in Germany. The lamp is the double ended HTI 400/D3. It has a rated lifetime of 750 hours and a color temperature of 7500 Kelvin. As always, we looked at all of our major working partners in the lamp manufacturing industry and after a long process, the Osram lamp was chosen as giving the best performance for the fixture.
    The light output achievable with this lamp is 9,300 lumens. The official figure for the MAC 500 fixture is 9,000 lumens so you can see that we lie slightly higher than this industry standard, light output wise. How do we do that with only a 400 Watt lamp compared to the 575 Watt lamp of the MAC 500. Well, part of it is due to the lamp itself, a significant part is due to the new glass reflector technology that we are using inside the fixture and finally, the third part is due to the fact that we are using an electronic ballast to fire the lamp. The electronic ballast also gives other advantages, but I'll come onto those later.
    This will be one of the most often asked questions that you hear - how is the light output compared to a MAC 500. Well now you know and the key here is that by achieving this output with a lower wattage lamp, customers will be saving money on their power expenses.
    Motorised Zoom system:
    A much requested feature from customers has been for a zoom system of some kind inside a mid range fixture. We are glad to oblige and have included fully motorised zoom in the MAC 550 capable of beam angles from 14 to 30 degrees. Being fully motorized it is possible to achieve any beam angle within the range. A number of competitors to the MAC 550 employ step zoom systems. These are wheel based and only offer two or three different beam angles. These are limiting and do not provide the same smooth effect as a continuous system.
    As you would expect the lenses inside the MAC 550, including the zoom system come with optical coatings to decrease light loss and to give a better picture quality in the final projection.
    The lens system also comes with remote focus control giving accessibility to the sharpness of the image projection.
    Dynamic Graphical Engine:
    The MAC 550 is quite simply the best in its class when it comes to the graphical possibilities.
    Firstly we put in a 6 slot, plus open, rotating gobo wheel. This wheel uses the same modular design base as the MAC 2000 gobo wheels, making them easy to change and easy to clean. Each of the gobo holders can take dichroic glass, structured glass or metal gobos, giving designers a wealth of possibility. Rotation / Indexing control is 16 bit as standard giving users absolute accuracy. A new set of gobos feature throughout this wheel.
    Then, we added a 9 slot, plus open, fixed gobo wheel. Once again this wheel features easily replaceable gobos, but is built to house the metal variety. Once again, a new set of gobo designs feature on this wheel. All gobos on both wheels retain the same size as the MAC 500, so any customers who have invested in custom gobos will be able to continue using them with ease.
    Further standard features for both of these wheels such as continuous wheel rotation and the gobo shake function are included, as you would expect. It's worth pointing out that these features which are well received and very well liked by our customers are not included in some competitive fixtures.
    Then, we went even further and added a gobo animation system. The same system that was pioneered by Martin in the MAC 2000 Performance and proved to be a huge success in many other segments is now in the MAC 550. A truly unique effect that no competitors can match! Technically, the system has exactly the same functionality as the system in the MAC 2000 Performance. This means that all of the effects achievable with a Performance are now available for users with a smaller budget - rising fla
    MvG
    Gerrit Schottert
    Controllux
  • PowerSound
    • Nov 2001
    • 1892
    Wordt weer veel kijken, testen, raken, babbelen op de PLASA .
    PSL Bvba powered by
    Yahama LS9-32 / MC7L-48
    • -Aart-
      • Jul 2001
      • 801
      Het "lijstje" ziet er zeer gaaf uit. Heb toch sterk de indruk dat ze hiermee kwa functies een stukje voorlopen op de concurrentie.
      Ben benieuwd wat de prijs zal gaan zijn, het klinkt allemaal niet goedkoop en vooral een stuk complexer dan de "oude" fixtures.
      Niet dat ik zelf zo een spot zal gebruiken , maar technisch interressant is het altijd wel.
      • LJ Gerrit
        • 479
        Voor meer info en een foto:
        De prijs zal ongeveer 20% hoger liggen dan de Mac500. Vraag J&H de exacte prijs.
        MvG
        Gerrit Schottert
        Controllux
        • Roland
          • Jan 2001
          • 480
          Alleen jammer dat ze de shutter en dimmer gecombineerd hebben.
          • DeMennooos
            • 1416
            Tja, weer geen CMY ....
            Greetz,
            DeMennooos
            • -Aart-
              • Jul 2001
              • 801
              citaat:Alleen jammer dat ze de shutter en dimmer gecombineerd hebben.
              Waarom is dat jammer ? Als de software het goed doet kun je ook gedimt stroben, of doel je op een mogelijk ander nadeel ?
              @ CMY: Zijn er effect MH's in de zelfde categorie die dat wel hebben ?
              • Jasper-Lichtbron
                • Jun 2001
                • 2155
                citaat:Geplaatst door -Aart-
                Mwa ik zie dat ook wel in, heb hetzelfde probleem met 518's van Martin (staat trouwens elders ook al in een topic). Als je alles dimt moet ook alles uit zijn (vind ik) en met onze tafel is dat dus niet zo. Wanneer je dan een strobo hebt lopen gaat ie vrolijk open en dicht, en heb je dus toch licht. Ik neem aan dat ze dit bij die 550 MH's wel anders gedaan hebben, maar toch... ik zie ze ook liever helemaal apart.
                • -Aart-
                  • Jul 2001
                  • 801
                  Apart betekent wel twee maal (vrijwel) hetzelfde stuk mechanika in je spot, ik kan me voorstellen dat ze dat niet doen ivm gewicht. Met een goede snelle dimmer-shutter moet het volgens mij bijna even goed (of slecht) stroben als met een speciaale strobe-shutter.
                  Aan de andere kant;
                  Ik kan me voorstellen dat je een strobe-shutter op een wat andere plaats in de optiek zou kunnen plaatsen, en mogelijk anders gevormde bladen geeft, een strobe-shutter behoefd immers alleen zeer snel te zijn, niet mooi lineair en gelijkmatig. Enigzins strijdig zijn de eisen voor dimmen en stroben dus wel.
                  Een (technische) reden die ik kan verzinnen waarom stroben in sommige fixtures op 100% gebeurd is dat de fabrikant bang is dat de shutter "bladen" bij het stroben anders te vaak een stapje overslaan (dus dat ze hun positie ijken tegen een aanslag iedere beweging, op het moment van full open) Met een aanslag aan de andere kant of een lichtsluisje is dat wel te ondervangen lijkt me.
                  • Martin Hoogeind
                    • 60
                    Het is wel degelijk jammer dat de shutter en de dimmer gecombineerd worden. ALs je gaat rock en rollen dan heb je graag een aparte feader waar je alleen maar dim-informatie onderzet. Als je dan bijvoorbeeld een shutter-chase maakt, kun je hem tevens ook dimmen. Shutters zelf zijn vaak ook sneller dan dimmers waardoor je een grotere ipmact met je shutter-chases gaat maken. Stroben gaat vaak zo snel dat je geen verschil met je oog waar kan nemen. Het probleem is dus alleen dat je geen, of weinig controle hebt over de dim informatie tijdens een shutterchase/strobe.
                    @CMY. De studiospot CMY is een vergelijkbare spot van Highend dij zoals de naam zegt over CMY beschikt. Hij beschikt zowieso over meer functies dan de MAC 500/550, maar voor de details moet je de specs maar even checken op www.highend.com
                    • JeroentjE
                      • 197
                      Hoi,
                      ik denk dat een gecombineerde/losse dimmer-shutter zowel voor- als nadelen heeft.
                      Nadeel losse dimmer/shutter;
                      Wanneer je voor bv een MAC 600 en pre-que maakt (pan/tilt op blind, color op open, shutter op strobe en de dimmer dichtlaat) zie je toch een grote hoeveelheid strooilicht wat knippert. Dit is overigens echt niet alleen bij martin zo.
                      Voordeel gecombineerd;
                      Strobo effecten kunnen sneller geprogrammeerd worden en over het algemeen sneller geexecuted worden. Klote kan het idd soms wel zijn als je een device met een trage dimmer hebt. Strobo accentjes met bv een movitec WL; daar hoef je niet eens aan te beginnen, daar is de dimmer veel te traag voor en zelf een shutter chase proggen is een beetje veel werk [:I] maar zal toch moeten gebeuren ..(Dus geen built-in functie's aanzwengelen maar zelf iets bakken).
                      Moraal;
                      wil je echt knipperen, hang er dan wat atomic's in ofzo ..
                      Nigel Tufnel: "Eleven. Exactly. One louder."
                      Marty DiBergi: "Why don't you just make ten louder and make ten be the top number and make that a little louder?"
                      Nigel Tufnel: [Pause] These go to eleven."
                      • Michel van Ginkel
                        • Nov 2000
                        • 133
                        Het spijt me dat ik er weer over begin, maar ik heb met m'n 250+sen en lightjockey nergens last van... Intensity's (dimmer) zit gepatcht op een faderbordje via DMX-in, strobe wordt geregeld door LJ.
                        Ik kan keurig van 100% naar 0% dimmen tijdens een strobe sequence en kan geen van de bovenstaande problematiek ontdekken...
                        Denk niet echt dat ik er bij de 550 nu ineens wel last van zal hebben.
                        Met andere woorden, ik denk dat het toch ook wel een beetje tafel afhankelijk is...
                        Groet,
                        FOX
                        DFProductions
                        DanceForest Drive-in shows
                        Ik heb het gevoel dat ik wordt uitgeschud... <img src=icon_smile_sad.gif border=0 align=middle>
                        • LJ Gerrit
                          • 479
                          citaat:Geplaatst door Michel van Ginkel
                          Groet,
                          Yep, je hebt gelijk. Veel hangt af van de controller.
                          Deze week komen de eerste exemplaren binnen van de Mac550, ik ga het meteen testen en vermeld het in deze Topic.
                          Overigens ga ik hem testen met de MaXXyz, Martin LightJockey, Avolites Pearl 2004 en LSC MaXim LP.
                          ps Personality files reeds gereed voor diverse controllers.
                          MvG
                          Gerrit Schottert
                          Controllux
                          • DeMennooos
                            • 1416
                            Hierbij wil ik graag aanbieden om hem ook op de Status Cue te testen.
                            Personality file zelf zal een probleem zijn, maar dan wordt het werken met Generic DMX.
                            Ik weet van HES dat ze met een universiteit in de States bezig zijn om de software toch door te ontwikkelen omdat de tafel nog steeds veel gebruikt wordt wereldwijd.
                            Greetz,
                            DeMennooos
                            • JeroentjE
                              • 197
                              Even omhoog halen,
                              ben zojuist bezig geweest met een programmeersessie met de MAC 550's en ben zwaar teleurgesteld wat betreft de dimmer. Wanneer je de dimmer hard laat werken gaat hij na een aantal flashen (+/- 20) niet helemaal meer dicht. Pas na een harde reset doet ie 't weer.
                              Ik ben bezig geweest vanaf een GrandMA en heb tevens een 24/6 gebruikt om te kijken of het eventueel aan de tafel zou liggen. Niet dus.
                              Verder zitten er een aantal leuke features op.
                              Oja, misschien niet onbelangrijk maar het gaat om een spot met software versie 1.49 als ik me niet vergis ...
                              Comments?
