Goededag,
Ik heb hier thuis nog 4 stuks rcf L15 P801 woofers liggen.
Nu zag ik een aantal kasten op internet te koop staan .
1 van die kasten is de enkel 15" baskast B09/9 van de beyma site.
Zou het mogelijk zijn de rcf in deze kast te plaatsen?
Testen is natuurlijk de beste manier maar ik doe lavast even een vooronderzoek.
Hier de gegevens van de speaker.
L15P801
Typical characteristic
Nominal Diameter 380 mm 15 Inch
Rated Impedance 8 W
Power handling capacity
(1)
350 Watts
Sensitivity 1W, 1m
(2)
100 dB
Frequency Range
(3)
54-5200 Hz
Power Compression
(4)
@ -10dB power / dB
@ - 3dB power / dB
@ rated power / dB
Distortion
(5)
2nd harmonic 1.5 %
3nd harmonic 0.4 %
Effective Piston Diameter 330 mm 13.0 Inch
Maximum Excursion Before Damage (peak to peak) 30.5 mm 1.2 Inch
Minimum Impedance 6.9 @ 250 Hz W
Voice Coil Diameter 76 mm 3.0 Inch
Voice Coil Material Copper
Voice Coil Winding Depth 12 mm 0.5 Inch
Number of layers 2
Kind of layer round -outside
Electrical polarity A positive voltage applied on the red terminal produces
forward cone motion.
Thickness Top Plate Depth 7.5 mm 0.3 Inch
BL Factor BL 21.5 T x m
Effective Moving Mass Mms 73 gr
Thiele - Small Parameters
(6)
Resonance frequency Fs 44 Hz
DC resistance Re 5.6 W
Mechanical factor Qms 4.5
Electrical factor Qes 0.25
Total factor Qts 0.23
Equivalent Cas air load Vas 180 liter
Effettive piston area Sd 0.085 m
2
Max. linear excursion
(7)
Xmax 4.1 mm
Linear displacement volume Vd 350.5 cm
3
Voice - coil inductance @ 1KHz Le1K 1.63 mH
Half-space efficiency Eff 5.9 %
Mounting Information
Overall Diameter 387 mm 15.2 Inch
Bolt Circle Diameter 371 mm 14.6 Inch
Bolt Hole Diameter 6.5 mm 0.3 Inch
Baffle Cutout Diameter
Front Mount 355 mm 14.0 Inch
Rear Mount 353 mm 13.9 Inch
Depth 155 mm 6.1 Inch
Volume Displaced by Driver 5.5 liter
Net Weight 9.1 Kg
Shipping Weight 10.2 Kg
1
AES standard (50-500) Hz.
2
Sensitivity is based on a 100-1000Hz pink noise signal for an in put 2.83V @ 8
Ohms.
3
Frequency range is defined as the frequency extremes over which the response is
-10dB relative to rated sensitivity.
4
Power compression is the sensitivity loss at the specified power,measured from
50-500Hz,after a 5 minute AES standard
pink noise preconditioning test at the specified power.
5
Distorsion is measured at -10dB rating power,from 100 to 500 Hz.
6
Thiele-Small parameter are measured after 2 hour exercise period using at the
power handling capacity.
7
Mathematical Xmax
L15P801
Rated Impedance 8 W
(1)
350 Watts
Sensitivity 1W, 1m
(2)
100 dB
Frequency Range
(3)
54-5200 Hz
Power Compression
(4)
@ -10dB power / dB
@ - 3dB power / dB
@ rated power / dB
Distortion
(5)
2nd harmonic 1.5 %
3nd harmonic 0.4 %
Number of layers 2
(6)
2
(7)
Xmax 4.1 mm
3
Net Weight 9.1 Kg
1
2
Ohms.
3
4
5
6
7
Mathematical Xmax
