mijn nieuwe setje
  • speakerfreak
    • May 2002
    • 1446
    mijn nieuwe setje
    hoihoi...
    eindelijk begint het ergens op te lijken...
    het begon met de 12 6inch B&C speakertjes... eens teste
    [img]http://groups.msn.com/_Secure/0UQDZAhIXJ6fcFC9vgVTqjGEQVVsNHFWJgHRSwPOtMSTgu5wKy OBV3ycDLhnOsMB4FnSdkI2xwJx2eaPZ2wr095QF2uywjy5*5*y Qlr9UXSV0Mj6fPgyGzPUh*NDMF!l7/6inch,%20speaker1.JPG?dc=4675437656526490403[/img]
    [img]http://groups.msn.com/_Secure/0TQAAAGAWUWt1Fy!7MaXovPVM0kec4280cXjgD0Y3ldQXK9Uv5 iNG4*X*dGHBV!InN7Oiroi4tl54bbpQPcW6ikLx394Brbm7NlM FAZCRnQfh8SsLghh9mQ/6inchspeaker2.JPG?dc=4675437656557307589[/img]
    toen kwamen de subjes
    [img]http://groups.msn.com/_Secure/0SgAAADUUmdLvTugti29jUUJ6QHmopmd2le4zmUXVhCyCweFDR ci!eu34sNEaD1xSRe5oAqZK*gStmIEIGrH7S6LMQ7Ynpp75C3f vGheYU!4!9M1mpJcjdQ/kast%201.1.JPG?dc=4675440730406682770[/img]
    ff spelen[:I]
    [img]http://groups.msn.com/_Secure/0TgDPAr4VPUcee4cb7vXW5GWcaQYp6aFAvgE!dPsyGoXOCaQYW ApDFYqDxgKsAJNZ1TWM6OuAeZsPN7vRR2iPncehw2y53s1xA*o 0GiSFGScHK57HbNsNwA/kast,pzb38,2.1.JPG?dc=4675440730441285890[/img]
    losee speakers, van B&C pzb40
    [img]http://groups.msn.com/_Secure/0RQDLAhsTfH!ofSOMQ9BJhky0W7O!5QaTtIyXkNah9FTARdLWo r5wQVkmaMXPvWsRG6afP*O8LHk9H!SPL!SKx*LsFx2rLj0ETyQ IBD41RfE/pzb40.JPG?dc=4675442881382048511[/img]
    tophats erin flanse, blegh
    subs zonder schuim
    [img]http://groups.msn.com/_Secure/0TgAAANwWBJC1mdxkTn7X2unciLTY4DBwmzg6Ryxd!oXn0V5BJ hqH93GIcgh5KXiSZMlXyjC4LduDk27!vta9P4SekTer*jFmIGE rD6ciylBOSurHhmW47A/subjes,0schuim.JPG?dc=4675442879418766465[/img]
    topjes zonder schuim
    [img]http://groups.msn.com/_Secure/0UQDLAmwXz8Ffe9SCe8LSQIV1HBJz8m0OBetl!8Yx3Xb53cFH9 ye*oKY9TbxP3u1ajdtKIH*AsoHxOD9CSNI!Q4OMm5P8w2zxVcG yxYzEcKEJijqU6zmsb6N5hPbXh*lw/topjes,%200schuim.JPG?dc=4675442879498350619[/img]
    bas met schuim
    [img]http://groups.msn.com/_Secure/0UAAAADgXx6!1mdxkTn7X2omvdlbq56qe395e5WO!bZVMJMWeJ t7aOVL66IkSeO9C8HGUKr6WwLF7mu9WQi8BTuf3p3ss8PUlW6J yrkni3ZzD8*fiMW7ZcQAAAAAAAAAA/subjes%201schuim.JPG?dc=4675442879377630223[/img]
    topjes met schuim
    [img]http://groups.msn.com/_Secure/0UAABGEEXb7Jfe9SCe8LSQFHkxT3Y8EFc!Iv4mSFiy*Lfu5m36 Wp1AYYWVp*071niUl4SDyHqcgpblUP!wMVjx3h0K0nt!9ecEuy 52cfx8DjaVRahwXDaN3SCARgAcAEY/topjes%201schuim.JPG?dc=4675442879460698072[/img]
    geheel met schuim
    [img]http://groups.msn.com/_Secure/0UwDPAp0XctWzlnSEX7O07nL7uwm2aKiJn0ZoLKTqQisVC8b0k N295yHhymbPxw2kRGRUDja9F!g9dhApt*rSutPs980WFGZk8NM SI2FSTV*aReRz2g7X1ZgqXOXYldFH/geheel%201%20schuim.JPG?dc=4675442879337241623[/img]
    hopen dat ze het doen anders ben ik voor nix een uur bezig geweest
    maargoed, echt testen heb ik nog niet kunnen doen... 1400watt rms per sub @8ohm moet erop... aangezien ik hier een dynacord van 50watt rms @8ohm heb en een skytec met 100 skytec rms wattjes... gaat het nog niet echt...
    subs zijn deze: http://www.speakerstore.nl/show_construction.asp?Id=2
    gebruikte speakers per kant: voor het laag 1 keer pzb40 van B&C, mid 2x pev13 en voor het hoog 1inch eminence
    word sub,stokkie,top maar paaltjes moeten nog komen hoop ik deze week te hebben... ben benieuwd wat jullie er van vinden
    Derbi Gpr Project aan de gang
  • speakerfreak
    • May 2002
    • 1446
    okej, modje?!!!?[:I][:I][B)] kun jij het voor me maken[8)]
    naja dan maar ff losse links,
    beter idee, http://groups.msn.com/JHFORUMFILES/b...o&PhotoID=1035 dan gewoon volgende kom je ze allemaal tegen.
    alvast bedankt voor de moeite
    • bertuss
      • Jan 2002
      • 816
      je doet je naam wel eer aan. mooi gefixt hoor.!
      • Stefke
        • 259
        Ziet er goed uit, Ik wou dat ik ok zo mooi kon afwerken
        Maareh, mis je niet een heel klein beetje veel mid?
        Volgens mij benen die PEv13 niet echt een sub van 1400W RMS bij. Of ga je de subs redelijk hoog laten gaan?
        ah zo dan
        • speakerfreak
          • May 2002
          • 1446
          hoi,
          een beetje laag mid mis ik inderdaad... maar subs kan ik behoorlijk ver laten doorlopen door de kleine behuizing van de woofer... staat 3 weg actief gecrost, ~300hz, en mid op hoog, ~5000hz...
          schuim van de topjes flodert er lekker bij, moet ik nog klitteband kopen... of van mama jatten
          daarna weer de profielen erop... voordegene die het niet wisten, dit waren oude SA kastjes... ik heb het front er maar uitgehaald... nieuwe frontplaat erin, de 2 topkastjes nemen zeer weinig ruimte in, en subjes zijn lekker krachtig maar toch klein... komt dus mooi uit want ik zit nogal krap in vervoer...
          subs(bas) zijn trouwens 97db... topjes volgens winisd 103db, 1x6inch is 120watt rms, staan paralel dus zou 240watt rms worden, op de HF drivers staat 100 watt 16ohm...
          maargoed zijn dus wel lekker krachtige topjes, alleen jammer van de Xmass van de 6inchers, maar 0,6mm en dat merk je wel in het laag/mid.... en heb hier nu nog 8 losse PEV13 van B&C liggen maja.
          bedankt voor de complimenten
          • Stefke
            • 259
            3 weg actief gecrossed?? je had toch maar 2 amps?
            ah zo dan
            • speakerfreak
              • May 2002
              • 1446
              jup, en van 1 van die versterkers (dynacord)doet zelfs het linker kanaal het niet meer skytec links=sub, skytec rechts=mid, dynacord rechts=hoog is dus maar 1kant aangeslote nu
              • Pieter Huijgen
                • 766
                Vooral die subjes zien er netjes uit! Hoe heb je die handvaten er zo mooi ingemaakt? Met de bovenfrees?
                • Pino
                  • 390
                  Netjes gedaan!
                  Kan je de subs niet op het monokanaal zetten van jou X-over en deze dan toch laten doorlopen tot +/- 300 Hz? Dan heb je toch iet of wat stereobeeld; je moet dan je toppen natuurlijk wel passief filteren , maar dan heb je wel genoeg aan de amps die je nu hebt.
                  Succes,
                  Pino
                  • speakerfreak
                    • May 2002
                    • 1446
                    het zit zo...
                    ik was van plan de subs zelf te maken, maar toen hoorde ik van Frederik dat hij zijn kasten wegdeed voor een (voor mij dan)prima prijs...
                    Als ik ze zelf gebouwd had had ik niet deze handvaten gebruikt, maar kant en klare grote handvaten 20x13cm? vind ik stuk lekkerder tillen, deze handvaten tillen prima als je ze alleen tilt met ze 2en vind ik gewoon kut gaan omdat je hand ervan de onderkant in moet en bij grote handvaten kun jeje hand vanaf de boven kant ``erin doen``.
                    Duidelijk he[}]
                    wel was ik eerste ook benieuwd hoe het zat met de handvaten, maar is makkelijker dan ik dacht, zal deze week nog wat fotos maken...
                    Tophats heb ik afgelopen dagen gedaan, moet nog ff geverfd worden is ook wel netjes nu.
                    Ook had ik dan inplaats van 25mm berken,15mm berken genomen, zonder de speaker weegt de kast echt nix maar komt toch 12.5 kilo speaker in, maar kasten zijn alleen goed te tillen dus dat is mooi.
                    zal vandaag nog wat fotos maken van topkasten en subs nu op paal
                    Van het het verhaal van crosse, staat nu zo ff aangesloten, moet nog 250euro an me pa afbetalen en 100 euro telefoon rekening[:I] dus kan echt geen cent uitgeven, heb hier berekend schema liggen, freq. tussen mid en hoog blijft 5000hz. als ik filtergebouwd heb kijk ik of er nog wat gedempt moet worden.
                    moeten dus 3 versterkers komen, 2 versterkers die gebrugd ongeveer 1400watt leveren, en 1 versterker (2x 300watt rms@8ohm) voor de topkastjes) filter gaat eruit, want is een 3weg monarch filter... werkt nog wel maar mag wel ietsje moderner
                    • speakerfreak
                      • May 2002
                      • 1446
                      • speakerfreak
                        • May 2002
                        • 1446
                        • speakerfreak
                          • May 2002
                          • 1446
                          okej, wel 2 fotos die weer willen lukken, hier van de andere linkje.
                          top op stokkie:
                          sub met stokkie
                          zijkant top
                          owja, van de tops moeten de profielen er nog op, en het schuim zit er nog niet strak op, beetje rommelig dus
                          • skylineshow
                            • 71
                            mooie kasten....
