XI-8
8" / 1,375" Full range installation cabinet
Made for D8429 bracket
Recessed Speakon chassis, no inner adapter
Smooth frequency response.
Rotatable 90 x 60 horn
Detachable metal grill
The XI Series is designed for installation use. It has special mountings at the backside which fits the DAP D8429, Compact speaker wall bracket but also the K&M 24470/80 bracket. To create a nice design it has no inner adapter and only one grip on the backside with a recessed Speakon chassis. It is finished with scratch resistant paint and a detachable metal grill. The horn can be rotated if you like to use the cabinet vertical. It has a HIFI sound quality and can handle high pressure levels.
Specifications
Nominal Impedance: 8 Ohm
Continuous power: 250 Watt
Program power: 500 Watt
Peak power: 1000 Watt
Freq. Response (-3 dB): 65 – 18.000 Hz
Freq. Range (-10 dB): 55 – 20.000 Hz
Recommended High Pass Filter: 55 Hz, BW-24
Crossover Frequency: 3300 Hz, 12 dB/Oct
Sensitivity (Full Space): 94 dB / W / m
Peak SPL at 1 m (Theoretical): 124 dB
Nominal Dispersion (HxV): 90° x 60°
Dimensions : 260 x 270 x 430 mm
Weight: 11.4 Kg
Lees meer over de DAP Audio Xi-8 8" / 1,375" full range installation cabinet
